Wilkins Model 70 Pressure Reg.
I have a Wilkins model 70 pressure regulator on my irrigation system. The pressure is much too high, I'd guess 70-80 - will get a guage tomorrow. Question:-
How many C-C turns of the nut are required to see a reduction in the pressure - Should we have it screwed down quite a ways to see an effect? It has still a half-inch to go and becoming stiff to turn and pressure still high.
Any input on this would be appreciated
Thank you,
John R.
Thank you,
John R.
Thank you,
John R.
Thank you,
John R.
Shacko,
thank you, I have installed a gauge and see approx 45, at times dropping to 40. My six Orbit Valves, a two manifold setup are leaking a little from underneath the valves, not the taped joints. Tomorrow I disassemble, check everything and reseal all. I may discard the Orbits and go back to RainBird if this persists.
Appreciate the input.
John R.
John R.
