pvc
Old 12-06-00, 01:16 PM
Guest
hello
can i cement a piece of 1/2" pvc into a piece of 3/4" pvc pipe to hold the 35 lbs. pressure at my out door faucet?
thanx
peter
Old 12-06-00, 01:48 PM
Mike Swearingen's Avatar
Received 1 Upvote on 1 Post
Cool
Sure, but you have to use a 3/4"-to-1/2" reducer pvc fitting for it to hold water pressure.
Can't just glue two pieces of different sizes direct to each other.
Old 12-06-00, 02:10 PM
Guest
reply to pvc
hi old guy
thanx for the reply
i'm still curious why the 1/2" which has o.d. of .090" less than the 3/4" i.d. won't fit snug but i'll take your word for it.
what do i ask for- a 1/2 to 3/4 adapter?
thanx
peter
Old 12-06-00, 03:29 PM
Cool
Hi, Peter!
I'm not a plumber, but cpvc (for hot water lines) and pvc (for cold water and drain lines)fit together fairly tightly in order to bond (think of the glue as chemically melting, as in welding, the two pieces together with very little tolerance).
Both pieces need to be clean, dry and sanded to create a tight bonding surface. I've worked with pvc plumbing for many years, and I've just never known it to hold under pressure without the proper (same) size fitted together.
Just ask for a 3/4"-to-1/2" reducer fitting. Could be a bushing, or an o.d. fitting. Depends on what you need. Just look around the plumbing section, and you'll see all kinds of fittings.
After cleaning and sanding, I would use pvc primer and then glue, THEN you know it won't fail under pressure.
Edit: And always give your fittings a "push-together and quarter-turn twist" just after you glue them to be sure that they're seated fully and the glue is evenly distributed.
Good Luck!
[Edited by OldGuy on 12-06-00 at 09:35]
Old 12-06-00, 04:25 PM
Old Guy, you ARE a plumber, by golly.
John
Old 12-06-00, 09:21 PM
L
npd424, what are you looking at?? I just tried to slip a 1/2" PVC pipe into a 3/4" PVC pipe, and it won't fit. The O.D. of the 1/2" is greater than the I.D. of the 3/4". Only thing I can come up with is that you are looking at pipe that is less than Schedule 40. If that is the case, don't use the pipe you have in your garage for this project. Upgrade it to Schedule 40, use the proper fittings to do what you want to do. and be happy. The alternative is to save about a dollar by using Class 125 pipe, and suffering hundreds, or thousands of dollars of damage when it fails!! It's your money!
Old 12-07-00, 12:15 AM
Guest
Thumbs up 3/4 to 1/2 reducer fitting
hi old guy
i'm off to home depot and thanx for the time and advise
peter
