I have an upstairs toilet from which an odor is coming...it seems to come and go...Does anyone have any suggestions as to the cause and possible repair? Thanks
Sounds like a vent pipe is partially clogged above the bathroom. Go up on the roof (carefully) and clean out any leaves, debris.
Should solve your problem.
Good Luck!
Good morning. Does anyone have any ideas on how to fix a leaking pvc joint, without replacing the whole thing? There are several parts and that would be very difficult. I thought I would try pluging the leak with more cement. Should I prime first? Any chance this will work? Thanks.
I have a Crane water pump. My power was off yesterday and now I have to prime the pump to get the water started again.
If you can give me some step by step instructions; I really would appreciate it.
LadyBee
