Unvented Shower drain length question
Old 08-12-10, 05:42 AM
I figure now is better than later to know if my plan is flawed.
I am putting in a new shower and the planned drain has about a 48" unvented run to the vented waste using all 2" ABS. Dimensions of the layout will be apprx a 8" drop to the P-trap and a 42" horizontal run to a long turn wye.
If I read the code correctly, 2" is good for a combined 60".
The drain should vent itself for this length, correct?
Am I good with this, or am I missing something?
Thanks for any advice.
Old 08-12-10, 11:52 AM
shacko's Avatar
If there are above fixtures connecting to the pipe you are tying into you can't do it.
Old 08-12-10, 12:49 PM
Thanks shacko,
The shower is the furthest upstream on a secondary line (vent). Downstream of the wye is the tub. These are the only 2 fixtures on the run. OK now?
HTML code is On
