Convert Washer Hookup to Slop Sink
Old 09-11-10, 06:33 AM
I know that the washer hookup HOT water is not controlled. It is HOT ! I want to use the washer hookup to a slop sink as I have moved washer into the house. Is there a screw on mixing valve that I can use ? If not, what is the best solution to achieve this goal.....
Thanks !
Old 09-11-10, 07:54 AM
chandler's Avatar
Received 2 Votes on 2 Posts
Welcome to the forums! The hot water from the washer hot water side should be the same temperature as your household hot water, say at your kitchen sink. Is it supplied by a different water heater? If so, it could have the temperature set too high. Let us know.
Old 09-11-10, 12:33 PM
shacko's Avatar
I don't quite get what you are talking about, the hot water is controled by the valve in the wash machine and controled by the faucet on a slop sink, need more info.
HTML code is On
