Galvanized water line
Old 10-25-10, 04:42 AM
B
I recently had a plumber over to repair a leak I had in my front yard in the main line from the street to my house. He told me that because I started using fertilizer on my grass then I will have to eventually replace the entire galvanized line due to corrosion. I find this hard to believe that my house (built in 1967) is just now experiencing corrosion issues due to my one season of fertilizer use.
On another side note- I'm in the process of getting irrigation quotes and was told by one company that the main line needed to be a certain size in order to use as an effective irrigation source. What should I replace it with and can I increase the size of the pipe to help pressure issues that we experience when running more than 1 or 2 water-related items?
Old 10-25-10, 05:19 AM
P
Temporarily Suspended
Galvanized pipes eventually rot, with or without fertilizer. For years, copper was used as a replacement. I don't know if PVC or Pex is used these days. A larger pipe doesn't always mean more pressure.
Old 10-25-10, 01:47 PM
shacko's Avatar
