Delrin sleeves
Delrin sleeves
Hi, I recently connected an undersink water filter using vinyl tubing and brass compression fittings. Everything works well but when I was in the hardware store the other day I noticed they sell plastic sleeves called delrin sleeves in addition to the normal brass sleeves. Is it ok to use brass sleeves on vinyl tubing or is it going to cause a problem and should I go back and replace them?
Thanks
Thanks
It shouldn't be a huge issue. I believe the brass ferrules can actually crimp off the plastic tubing if overtightened. I use the correct type now...but in the past I didn't always and never had a real problem.
Pro's should be around.
Ack...thanks shacko...I forgot about the brass insert....
And I never even knew there were actual vinyl hoses for these type of connections!
Thanks for the help. I used the brass inserts but used brass sleeves instead of plastic ones. I will go back and redo the connections with the plastic sleeves. Do you have any recommendation on how tight I need to screw down the compression nuts?
You don't have to get carried away when you are tightening compression fittings on plastic. just make them reasonable, if they leak ( small drips ) you can snug them up with the water on until it stops. Use two wrenches so you don't twist something, luck.
That picture is only an illustration, you would have to check out the exact tube to get its pressure rating.
