1-1/2" vent pipe, move ?????
Hello, thanks for looking and considering my question.
I am going to install a bath faucet coming out of the wall. I ran HEAD ON into the vent pipe. My question is can I ZIG-ZAG it to allow for such?
I need to cut the pipe, install a glue a 90 to the left, then a 90 up, then a 90 right, and finish with a 90 up to the pipe going thru the roof that I just cut. I will be going left approx. 8", up approx. 4" then back to original vent pipe going thru the roof.
Thank You,
Dale in Indy
Thank You,
Dale in Indy
No expert by any means...but could you use 45's instead?
I may be thinking of something else though. Since it's just air...seems like it wouldn't be an issue.
Gunguy45--is close, you should use 45s on the line until you get 42in. above any fixture connected to it, then you can use whatever you want; allways use the least amount of angle you can get by with.
I can't use 45's. I need to go STRAIGHT to the left, then up, and then over and hook back up.
This is inside a drywall wall, I can't get to 42" above a sink vent connection either.
Thanks, more comments are needed and welcome.
Dale in Indy
Dale in Indy
Update.................
I went on line thru GOGGLE, and found a plumber that discusses VENTS. Pictures too. He says vents often are HORIZONTAL, but need a slight fall so as rain water NEVER blocks the air flow. Don't want a TRAP so to speak to happen.
I believe I can drop down a bit lower and go the 45 method, which will assure a FALL.
Thanks,
Dale in Indy
Thanks,
Dale in Indy
Thanks,
Dale in Indy
Thanks,
Dale in Indy
