Wounded elephant?
Wounded elephant?
My one toilet,(out of 4 in the house), sounds like a wounded elephant when it is flushed. It is the only one to do it. Has gotten worse with the advent of cooler weather. Thanks, Kyle
Temporarily Suspended
Try to locate the source of the noise. Open the tank & flush it. Does it sound like the noise if originating inside the tank? Shut the valve & flush it. Is the noise still there?
Was it a ball valve or a stop valve? It is possible the stop valve gasket was loose and was fluttering in the valve. When you turned it off you corrected it 's position. Just a stab, but glad it worked out.
Oh, I see, you are calling the fill valve a "ball" valve because it has a ball on it. Gotcha. I was referring to the cut off valve (stop) near the floor. Yes, if it were to happen again, I would consider replacing the ball mechanism to a linear Fluidmaster 400. Let us know how things go.
