What type of shutoff valve is best?
Old 11-12-10, 03:51 PM
N
A couple of questions:
1) I am about to install a water softener and I am going to install a bypass system. What type of shutoff valves do you prefer? I have had bad experiences with all types, but wondered if one was better (i.e. works the best and longest).
2) I have a whole house shutoff valve (globe or saddle) that no longer works. It's soldered in and is in a tight spot. How feasible is it to replace the insides? It's about 20 years old - have they changed much over the years?
Old 11-12-10, 04:42 PM
chandler's Avatar
Received 9 Upvotes on 8 Posts
Without a doubt a solid brass ball valve. PVC and cpvc ball valves are worthless. You can change the globe valve washer, but if it is in a tight space, abandon it, leave it in the full "on" position, and install a ball valve downline in a more convenient place.
Old 11-12-10, 07:32 PM
N
I prefer brass ball valves too, but I have had a number of them seize or have the handle snap off lately - and they're not that old. However, I'll go with the ball valves anyway.
My whole house shutoff valve just spins, so I don't know if it's all the way open or not. I'll take the guts out and cap it.
Thanks.
Old 11-13-10, 06:20 AM
W
Received 1 Upvote on 1 Post
Over the years I have replaced all the valves in my house with brass ball valves. I think I probably have at least a dozen and I've never had a problem.
I recently put in a 3/4" Sharkbite ball valve as the main house cutoff. It took about 5 minutes to install. A little pricier than a sweat in valve, but the time saved was worth it.
Old 11-13-10, 06:34 AM
N
Did you remove the old main shutoff valve or keep it in place? I'm just curious as there's no easy way to remove my old valve or put a new in in it's place.
Old 11-13-10, 01:49 PM
shacko's Avatar
Thanks.
You can't buy the cheap chinese ball valves and not expect something to go wrong; buy the better American made and I don't think you will have the handle snap off.
Sound like you may have a gate valve on your main and the handle shaft has stripped out, take it apart and throw the internals away, and leave it in place, same thing if you have a globe valve; saddle valves are installed on the OUTSIDE of the pipe.
Old 11-18-10, 09:52 PM
Stick with ball valves such as
Hammonds
Nibco
Watts
Apollo
I am constantly removing B&K Mueller ball valves not even 3-7 years old because of the thin sockets and water making its way through the castings of that valve.
I like a lot of B&K Mueller products, but I won't install anything that has a short life where my customer base as a plumber is spending twice in a short period of time.
