Bathroom in basement
New here so please be gentle!
Thinking about a bathroom for the basement (unfinished at this time) but have a few questions.
I have an ejector pit that the furnace/ac drains into (from a floor drain) and also the washer (im assuming since its down there) I wanted to run the toilet, sink, shower drains into this ejector pit. I should replace the pump thats in there with something to handle the waste water?
Can I do this? Can I tie into the ejector vent as well? Do I need to worry about the washer drain? Im assuming (havent checked yet because the previous owner built a wall covering the plumbing) the washer drain is trapped?
I know I need to bust up the concrete to run the PVC. The location would put the bathroom maybe 10ft from the pit
House is 6 years old located north of Chicago (mchenry co)
Thanks for your help!
Gary
Gary
You do have some questionable hook-ups on that pit, your discharge line has to be a minimum of 2in, what you have is 1-1/2, you may need to get a new pump, an ejector pump must discharge a 1-1/2 solid ball to be legal, it dosen't look like there is a check valve on the discharge line, a no-no.
A lot of jurisdictions will allow you to vent into the sump vent. Don't forget that any vent comming off you fixtures of your new bath will have to be a minimum of 42in above the floor before you can run them horizontal, now all you have to do is start digging.
Its 1.5" out of the pit, into 2" that runs into the main discharge.
I figured I would need a new pump, so Ill change the pipes and add the 2" check valve.
Thanks for your help.
