How to clean a hot water heater coil?
Our well is high in calcium and we do not use a softener.
Our hot water heater coil (located inside the oil burner) get coated and the hot water flow gradually diminishes to a trickle. I estimate that the restriction is so great that the flow is cut by more than 60%.
I un-clogged it by putting CLR into the filter and then flowing the water through the heater. It sort of works but I don't feel that the coil is thoroughly cleaned judging by the flow and by the fact that the period between cleans keeps getting shorter.
I know that a softener would help but I am looking for a more efficient and safe way of cleaning that hidden coil first.
Received 1 Upvote
1 Post
I'm not a plumber, but if it were me, and the coil was that clogged up, I'd either replace it or take it somewhere like a radiator shop and get it cleaned out.
Don't know what to tell you about cleaning it out yourself, but I know that a water softener (had one for 25 years) would help you.
Good Luck!
Good Luck!
Thanks for answer. I should have specified that the coil is INSIDE the oil burner and I can't figure out how to take it out, or even if it is meant to be taken out. I don't want to mess with system too much since the entire house is heated using the same oil burner.
