jetted tub
jetted tub
I have a jetted tub that the button that controls the pump is very hard to press in . i thought the problem was the switch inside the pump so replaced the pump . i cant find any make on the tub itself so my question is how to replace that button and where to get it if i dont know the tub manufacturer?
Welcome to the forums! The switch is an air switch, so the air line from the button to the actual switch may have an occlusion. Are you able to see the tubing? If so, can you disconnect it from both the switch and the button and clear it?
