Routing Rules
Routing Rules
As long as I use a metal pipe/wire protector plate, is it okay to run pipe very close to edge of stud (near the drywall) instead of down the middle of the wall. I have to get around a large drain pipe.
Also is there a rule/guideline about max number of 45% turns between supply and fixture.
I am tearing out polybutelene and running new pipe. I have to choose slightly different path b/c PolyB could bend/curve and new pipe won't.
Thanks.
Thanks.
Are you using cpvc? You can run the pipe close to the edge utilizing a no nail plate, but be sure you haven't degraded the stud too much. If you already have a 2" pipe in there, you only have 1 1/2" left of total wood. The lesser number of turns lessens the friction of the water, but in normal home situations it isn't too much of a problem. Why didn't you run PEX? Just curious.
