toilet fills up on own
after the toilet has been flushed after some time passes it suddenly fills up again. how do i fix this. also my kitchen sprayer wont spray anymore. whats wrong.
The toilet sounds like a bad flapper valve. When you replace it, make sure you wipe the seat of the flush valve clean.
The kitchen sprayer could just need the head cleaned. Soak it in white vinegar overnite. Or it could be the spray head is bad, or it could be the spray diverter valve (inside the faucet, under the spout) is bad. You will need to do some troubleshooting (after the overnite soaking) to figure out where to go next. Repost with more info and one of us will walk you through it.
