Any sense in converting copper to pvc?
I'm turning my basement 1/2 bath to a full bath. This involves busting up the floor so I can rough in the new closet flange location as well as add the shower drain. It's iron/copper now and I'm going to be converting that to pvc starting as high up the drain stack as I can access. However, as far as the sink water supply, toilet water supply, and shower, should I just convert those over to pvc as far back on the copper as I can or just stay the course complete the runs using copper?
At $ 20 a length for copper how many pieces do you need to get? Are you doing this yourself? I just switched out a bathroom to PEX tubing. It is very inexpensive and much easier to install than pvc since all you do it unroll it like a garden hose. The one downside is that you have to buy the pex clamping tool which is between $50 - $100. A 100' foot length of pex tubing is only about $35 and if your really anal like me you can get red tubing for hot and blue tubing for cold.
Received 37 Upvotes
You can't use PVC piping on hot water. I think the small amount of copper necessary will more than make up for using an inferior (my opinion) product in what sounds like a relatively small job. Use PVC or ABS (whatever is currently in vogue in your area or matches what you already have) for any drainage piping.
Once you use PEX you'll never go back to copper. The fittings are cheaper. the pipe is cheaper and you can install it in a tenth of time and don't have to worry about catching things on fire of leaks. You know how much time you can spend with copper trying to re-solder a leak. With PEX if you ever do find a leak you simple cut off the crimping clamp and put another one on. The tool is expensive but I think you can rent it at Home Depot. Even if you can't it's worth the price just in parts savings alone.
Interesting. Never even heard of the stuff. I guess my problem with copper is it gets all green and I'm pretty certain that's bad.
Received 87 Upvotes
hey moveright. I’m no expert like the folks here. But I was surprised to find in my township copper was required for all supply lines for additions and new construction. It might have just changed recently because I can’t seem to find that requirement again – but I know for sure it was there (and good chance it still is).
