ABS to Cast Iron Joint
Old 01-17-11, 01:18 PM
WE have an old (40 yr) joint in the basement where black ABS pipe joins cast iron before going under the floor. This joint is leaking. How do I reseal it and what material/product do I use?
Thanks,
Old 01-17-11, 02:06 PM
lawrosa's Avatar
Super Moderator
What is it sealed with now? Lead? Rubber dounut?
Mike NJ
Old 01-21-11, 09:18 AM
Typically, you connect ABS to CI pipe with a no-hub connector, which is basically a tough rubber sleeve equipped with SS hose clamps. Hardware stores and home-supply stores have the popular sizes. If you have odd-sized pipe like me (see today's posting), you may have to search.
Old 01-21-11, 04:39 PM
shacko's Avatar
You have to order a transition fitting by the type of pipe and the INSIDE AND OUTSIDE measurments, you won't find these in a hadware store, you will need to get them from a supply house. Go to this link and it will give you the information you need; this is just one brand, most are similar.
fernco, fernco couplings, fernco coupling, flexible pipe connectors, fernco fitting, flexible couplings | Fernco
HTML code is On
