Backflow Preventer / Check Valve?
I live in a townhouse and was told I should install a backflow preventer on my house. The septic system backed-up into some of the houses in the community recently.
I have a 3'' PVC waste pipe in my basement. What type of valve should I put on this line to protect the entire house from a septic system back-up? Where should I install this?
Thanks.
Thanks.
What are the chances of a backflow from a septic tank reaching my house if my plumbing is done correctly?
I just found out to install one I need to cut my dry wall to make it fit. As a result, I do not think I am going to install one.
Also, I was told they need to use a rubber connector on the PVC to connect the valve in. Is this true?
