Need a 3/4" PEX to 1/4" tubing recommendation
Our house has PEX piping throughout and while I have no issues with it, I'm having a hard time finding a solution to what I thought would be an easy DIY plumbing task.
I installed an under-the-counter water filter and used a saddle valve off the cold copper line to the faucet. I'm not a huge fan of saddle valves and I was in a hurry but now I'm thinking of cleaning up my install and doing it properly. I have a 3/4" PEX line that I would like to source from and connect to the 1/4" tubing that feeds the water filter.
My first thought was a 3/4" to 1/2" tee, crimped, and then 1/2" PEX to a reducing quick connector, 1/2" to 1/4". Then I'd connect the 1/4" tubing, maybe add a ball valve somewhere for good measure (John Guest makes a decent quick fit one.) My problem is that I cannot for the life of me find a quick-connect 1/2" to 1/4" reducer.
Does anyone know of a product or a better way to approach this (without soldering)?
Thank you in advance. Much appreciated.
If you have standard 3/8 compression valves for your cutoffs to the faucet, they make tees that feed 3/8" straight thru with a 1/4" connection. Very simple, unscrew cold supply to faucet, screw on tee, connect faucet to top, connect filter to side.
Here's one type...PlumbingSupply.com - Quick tee adapters for ice makers, dishwashers, water filters and various other water supply lines your local home center or plumbing supply should have something similar.
It looks like this might solve my problem:
SharkBite 23336-0000LF Compression Angle Stop 1/2" x 1/4" OD - Lead Free SharkBitePlumbing.com
So brass 3/4" to 1/2" tee, crimped, then 1/2" PEX to the angle-stop above, and finally 1/4" tubing to the water filter.
Thanks guys.
Thanks guys.
