outside faucet leaks
I have a Woodford model #17 anti-syphon outside faucet that leaks out of the top. I took the cap off and I can't get the assembly out of there, looks like I'll tear it up getting it out of there. Does it unscrew out of there, or just pop off.
The best solution is to replace the entire stem assembly. They are sold separately. Of course taking your old one would be a boost, but do it on a day when you can turn the water off to the house, unless this has a separate shut off (hopefully there was some foresight). Of course, you have the model number, so it may be as simple as asking for one at a plumbing supply house.
They other platic part unscrews. Use a pliers and grab the top and turn. The thing I cant remember if this part is reverse threads or not. It may turn CCW or CW.
Somtime the little washer in there on the plastic piece gets ****-eyed in there and just needs adjustment.
Sometime you can just turn that washer around and re-install.
Another issue is if the hose was left hooked up in the winter, that part is the first to freeze and crack.
Alot of homeowner say its frost free. It is but if you leave the hose hooked up in winter the water cant drain out.
Mike NJ
