capacity of natural gas line
The gas meter outlet is 1-1/4". One side of a 'T' branches to 3/4" 50 ft. supply to gas furnace (122k BTU). The other side of the 1-1/4" T is blanked off (previously used for swimming pool heater). I don't know how much pressure is on the outlet of the regulator, it's a Rockwell 107 and might be about 45 yrs old.
When my kitchen was remodeled last year, I bought a large 6 burner gas stove (102k btu). The sub-contracted plumber added a 3/4" 'T' close to where the 3/4" heater supply pipe originates and ran a new 3/4" 50 ft supply for the stove.
meter --> 1.25" T --> one side reduced to 3/4" --> 3/4" T --> furnace line & stove line.
So both the furnace and stove supply lines take their gas supply from the same short 3/4" nipple off of the 1-1/4" 'T' at the meter. It seems to me that this may be too much load for 2 high demand appliances and that each of these 3/4" supply lines should run separately from the 1-1/4" 'T' rather than from a 3/4" T. Individually, each line is sufficient according to a table I found on the web. But since they both originate from the same 3/4" nipple off of the 1-1/4" T I'm wondering if this design is under sized.
Should I have the lines redone so that they each branch off from the 1-1/4" outlet?
Or because the supply lines for the 2 appliances branch off only a short distance beyond the 1-1/4" line is the design sufficient? I don't notice any problem in the use of the appliances but I also don't know how to determine if the supply is adequate or not.
thanks, Jon
thanks, Jon
How far is the total developed length of the farthest appliance?
Furnace or stove?
Example if the stove is the furthest how many ft of 3/4"?
The 3/4" by itself can only supply 151,000 BTU @ 50ft. Now a appliance was added to it.
This is based on .60 specific gravity gas, .5 psi or less, and a .5 inch water column pressure drop.
Most likely you need to change the 3/4 to 1"
Mike NJ.
Furnace or stove?
Mike NJ.
Lawrosa:
Your questions are the crux of my query.
Each appliance is at the end of s separate 3/4" run of 50 ft (give or take a few feet).
My concern is that they are both fed from a 3/4" 'T' off of a 1-1/4" line and in my mind that reduces the flow to both appliances. Since both appliances are high volume consumers I am afraid I'm starving them. I'm trying to confirm if my concern is correct.
Jon
Jon
If you measure from the meter outlet both appiances are 50 FT?
Mike NJ
The T is right off the meter. Only 3/4" pipe enters the home. The total run of each of the pipes is 50 ft. They were not installed at the same time. When I had a new stove installed (108k BTU) the contractor ran a new line to the stove. The other line goes to the furnace (122k BTU). Both of these lines are 3/4 and start within a few inches of the meter.
jon
jon
