1/2 inch pipe coming into house, 3/4" inside--makes sense???
Old 05-18-11, 08:49 PM
Does it make sense to put 3/4" copper pipe inside the house if the pipe coming into the house from the main is only 1/2"? My contractor just did this. He says the 3/4" pipe will enable us to store more hot water in pipes. Is this true?? Any thoughts??
Old 05-18-11, 08:53 PM
lawrosa's Avatar
Super Moderator
Received 69 Votes on 61 Posts
Yes you will get more volume. I probably may have ran a 1" trunk line then branched off 3/4" arms then 1/2" to fixtures.
If you had all 1/2" and ran two showers you would detect lower pressure at the heads then if only one was on. Then have someone flush a toilet and you get a trickle. Not enough water.
Run the pipes in the home larger and you will get more GPM.
A larger diameter pipe will have a greater flow or GPM than a smaller pipe at the same pressure or flow rate.
It has nothing to do with hot water being stored per say.
What work did you do?
Mike NJ
