Safe Soldering
Old 06-11-11, 11:35 AM
kolias's Avatar
Received 9 Upvotes on 9 Posts
Safe Soldering
I renovate my bathroom and the back wall under the sink has a 5/8Ē melamine + the 1/2" dry wall behind. The hot and cold water lines coming thru the wall are only 3-1/2Ē long with compression fitted shut off valves. To remove the 5/8Ē melamine I have to remove both shut off valves.
I donít want to re install compression fitted shut off valves, I prefer to use the ones which you solder and in addition I will not re install a melamine piece at the back wall, I will just repair the drywall and paint it.
The 3-1/2Ē pipes coming thru the wall are connected to a T on the vertical risers inside the wall. I prefer not to touch the Tís because I may not be able to push the pipes to re install new Tís. This means that the new valves I will solder will be about 1-1/2Ē away from the existing Tís.
By soldering the new valves 1-1/2Ē away from the existing Tís would this melt the solder on the existing Tís? In other words how far can you solder a new valve from an existing soldered join without disturbing the existing solder?
Thank you
Old 06-11-11, 04:09 PM
H
Received 8 Upvotes on 7 Posts
Think you are ok
I have never experienced a problem with melting out an adjacent joint. My question is why do you not want to put new compression stops on rather than soldering? The 1/4 turn units are cheap and much more easily serviced in the future.
Old 06-11-11, 04:32 PM
lawrosa's Avatar
Super Moderator
Received 85 Upvotes on 77 Posts
Hi.
Solder quickly. If your not that experienced, and may overheat slightly, wrap the tee with a wet rag. That will keep the heat off.
Also take the valve apart when you solder, or open it. You can melt the internals.
Have a spray bottle of water handy. I alway had one. You never know. Something in the wall could catch fire. You can put it out quickly before disaster.
Mike NJ
Old 06-11-11, 05:14 PM
kolias's Avatar
Sounds good Mike
Unfortunately I canít solder quickly as the valve body needs some heat before she takes any solder. I will use ball shut off valves which require only keeping them open during soldering.
Nice tip to wrap the tee with a wet rag. Water spray is always close buy when I solder
Thank you
Old 06-11-11, 05:24 PM
kolias's Avatar
Sorry Handyman, I didnít see your post before
A few years back I installed a sink in the garage and used compression fittings to connect to the water lines. It must have been about 3 years after I did this job and one night when I came home from work the garage floor was almost flooded from one of these compression fittings. Talking to some friends I was told that these fittings are made in China and some times they can develop a crack Ė I guess thatís what happened in my case.
Since then I never used them, feel safer with a soldered join
Old 06-12-11, 06:58 AM
W
Received 30 Upvotes on 24 Posts
If you don't have a MAPP torch, now might be the time to get one. Higher heat will allow you to solder heavier fittings like a valve in much less time. In tight spots I will double up heavy duty tin foil and tack it behind the joint I'm soldering to protect the wall or insulation.
Old 06-12-11, 07:38 AM
kolias's Avatar
Didnít know about the MAPP torch, I have a soldering set I bought about 30 years ago and just keep changing the propane tank when needed but the MAPP sound a good deal. I guess itís time for a change.
Thanks Wayne
Old 06-12-11, 08:57 AM
lawrosa's Avatar
Super Moderator
Get one with a adjustable flame. Its good to have. They are alittle more but worth it. The others are simply on/off. They are not turbo tips so no need to worry about burning them out.
Mike NJ
Old 06-12-11, 10:10 AM
Z
Received 131 Upvotes on 122 Posts
hi kolias Ė
I got advice on the forum not too long ago suggesting the use of a MAPP torch. Wow! What a difference. I found it takes no time to heat up a 3/4 inch valve and be ready to solder. I couldnít believe the difference. Like you I was using a propane torch. (I also didnít have an on/off trigger which made things more difficult.) Seemed like it took forever to heat up a valve. In fact one time when I first started soldering, I gave up on a valve because (I thought) I couldnít get the valve hot enough.
I donít know what the proís think about this, but Iíve seen advice that says keep a fire extinguisher close by and a bucket of water. (My sisters eyes almost popped out when I sat them out when doing a job for her!). I always have the extinguisher and the bucket close by. But it sounds like the spray bottle idea is better than a bucket of water, much better control.
Good luck!
