Cleanout plug in a 1950's house
My son owns a 1950's house in St Louis. A plumber broke a ceramic or porcelain cleanout plug in his basement drain. He replaced it with a 4" plug and a lot of wax. When it started leaking, my son started cleaning off some of the wax and found that the fitting was 4 1/4". He is unable to find anything like it and needs some help. The plumber is no help. Can anybody help?
Thank you
Vance
Thank you
Vance
The drain pipe is cast iron. I was thinking that there are thousands of these houses with the same plumbing so there would surely be plugs for the cleanouts out there somewhere. Hopefully, we wont have to go back with the same jerry-rigging that was on there.
Vance
Vance
If cast iron you can get a cleanout cap from a home store. If then dont have them then a plumbing supply. You will be looking for a brass threaded cap. These are off sizes as you decribe. They are made for cast iron
Measure the opening and bring a ruler with you.
If you still cant find nothing they make a threaded lead cap. You thread it in best you can. Most times it will not thread at all. But since its lead, you tap it in with a mallet. They work pretty good and are used for this reason. Also when the threads get so messed up.
You most likely will have trouble threading it in. I would recommend getting the lead fit-all.
Brass C/O. First on the list.
PlumbingSupply.com - Clean-Out Plugs
Lead Fit-all.
Lead fit all plugs, lead plugs, threaded lead plugs : Nuclead
Hope this helps.
Mike NJ
Lead Fit-all.
Hope this helps.
Mike NJ
Replacement cleanout plug
You can get a rubber plug from most any hardware store to fit any size pipe. you tighten it up with a wing nut. you don't need any sealer.
