Installing IceMaker Line
I need to install the tubing that goes from underneath the sink to my refrigerater, but there is a door in between. Can I go over and around the door and then encase it with some kind of trim? Would that work? I mean would the water get there? Thanks for any help.
Pat
Pat
Hi
Yes you can. I guess no crawl or basement?
Make sure you use a full port valve and not one of those saddle valves.
Its code and the selonoids burn out on the newer fridges.
Mike NJ
Mike NJ
"I guess no crawl or basement ?"
Right. It is a concrete slab foundation.
Can you please tell me the difference between a full port valve and a saddle valve? Sorry if it is a dumb question.
Thanks.
Pat
Thanks.
Pat
hi patsy –
I’m not an expert by any means. Here are links to a saddle valve and a full-port ball valve. You can see the saddle valve straddles a water supply pipe. The saddle valve is tightened and punctures the water pipe allowing water to flow into the tube and on to the appliance. I don’t know much more than that. But as Mike says they are prohibited now (I guess everywhere?). Don’t know much about them but they are no good. A few years ago I was looking at a fridge from Sears and they clearly stated that they would not install the fridge if a saddle valve was being used. Wow! That is serious.
Good luck!
File:Saddle valve.jpg - Wikipedia, the free encyclopedia
http://www.jomarvalve.com/products/p.../S-100-STN.pdf
Good luck!
Zoesdad is correct. A 1/4 turn 1/4" angle or straight stop is the preferred valve like this. You get full volume of water to the ice maker.
Angle Stop Valve - 1/4 Turn Compression - AZ Partsmaster
The saddle valve only puts a 1/16" hole or so. The selonoids on the refridge burn out. Lacks volume for todays appliances.
It may just be a ploy for warranty purposes though. Thats a whole different conspiracy theory. But saddle valve are not to code in all the areas I am aware of. Why? They leak and corrode pipes I thing.
Mike NJ
Mike NJ
A tee adapter is also a good solution depending on the valves under the sink...PlumbingSupply.com - Quick tee adapters for ice makers, dishwashers, water filters and various other water supply lines
