Washer/Laundry Tub plumbing.
I currently have a laundry tub set up in my basement laundry room. The previous owners just drained the washer directly into the laundry tub. I am looking for a cleaner, more finished look. Next to the sink drain, there are two older drains that have been capped. I am new to plumbing, so I am looking for the easiest method for a beginner(If possible) Would the best method be to tee off the sink drain and use the same drain for both. Or could I open up one of the older drains, install a stand pipe from the drain, which would then go in between the studs and up to one of those recessed laundry boxes? Any help would be appreciated! Thanks
Ryan
Ryan
The only plumbing in this room is the sink drain, the 2 capped drains, and a standard floor drain in the middle of the room. All of the plumbing goes under the concrete slab so I don't know exactly where it might hook up to. There is a stack of plumbing not too far away from this room that goes from floor to ceiling and branches onto the main floor. Here are some pics of the drains...
Hi.
I am certain those two caps in the floor is a whole house trap. Pretty much dont touch it. Thats where you will most likely get a clogg if you put the wrong things down your drains. That is old plumbing but some towns still require them. Some let you remove them. You can hook nothing to those caps.
Now that I see you could use that sink drain for both. But you will need to get a vent up through the roof or tie into a vent 3 ft above the highest fixture in the home. ( On the same stack if you have more then one. ) This is code. You are grandfathered in I am sure at the moment.
You see once you start altering things you open a can of worms with old plumbing.
Heres what a whole house trap looks like.
Mike NJ
Mike NJ
Sounds way beyond my expertise and rather pricey. Looks like I'll just have to hook it up to drain straight into the laundry tub. Thanks again Mike. You're always very helpful!
According to Studors website, they are approved by the International Plumbing Code here in Michigan. And on my cities website they say they follow the IPC for plumbing standards. So it looks like they are allowed. I sent out an email to a guy from the building department just to confirm. Would this be an easier way to accomplish what I need to get done?
