gas pipe installation thru floor
How far from wall should I drill hole in floor to run gas pipe with shutoff valve, installing the valve to the pipe from the floor, leaving me enough room to put a shutoff valve (being able to turn valve to tighten to black pipe) between metal pipe and flex hose going to wall heater?
Hi,
You kind of answered your own question.
Enough room that you are able to screw the valve on or off while in the closed position.
Mike NJ
Mike NJ
