Gas line sizing?
Old 10-21-11, 09:12 AM
DaleC.'s Avatar
Gas line sizing?
I need to run a natural gas line from my meter to the back of my house to install a dryer. The total length of the run will be 90 feet. What size of pipe do I need to put in?
Please disregard, I have found the answer by surfing the web.
Old 10-21-11, 10:38 AM
lawrosa's Avatar
Super Moderator
Hi,
How many BTU is the dryer?
@ 90 ft
1/4 = 10k btu
3/8 = 22 k btu
1/2 = 40 k btu
Should not be more then 38K.
But possibly you want to add to it like a grill.
@ 90 ft
3/4 = 84k btu
1 = 160k btu
Hope this helps.
Mike NJ
Old 10-21-11, 12:20 PM
DaleC.'s Avatar
dry is 20,000 btu. What I found on the web says to use 1/2" for a 90ft. run. 3/8" would be a lot lighter to run. I am planning on exterior run just below the overhang on stucco siding.
Thanks for your reply.
Old 10-21-11, 01:04 PM
Did you account for the effective length of all the fittings AND for any other usage off of this piping?
Old 10-21-11, 01:32 PM
lawrosa's Avatar
Super Moderator
As Furd suggests you should run 1/2".
Mike NJ.
Old 10-21-11, 06:57 PM
DaleC.'s Avatar
This will be a dedicated run from the meter to the dryer. Nothing else will be attached.
HTML code is On
