1" Inch Poly yellow pipe underground to Generator question
Old 10-26-11, 10:04 AM
I will be running a 1 inch yellow pipe underground from meter about 80-90ft to Generac generator. I will be installing 2 ENDOT Anodeless Riser, 1 In. IPS x 1 In. MPT at meter and then at the end by Generator. Question is, how do I attach the riser to the yellow pipe. I take it I have 1 inch pipe so it get's attached to a 1" riser? Correct? I will have to put a reducer at the end by generator to bring the 1 inch down to 3/4 with a ball valve. Looking for input or a better way.
Riser:
Anodeless Riser, 1 In. IPS x 1 In. MPT - Buriable Gas Fittings - Buriable Gas - 4EHJ7 : Grainger Industrial Supply
Yellow pipe:
Gas Tubing, Yellow, 1.05 In OD, 150 Ft - Buriable Gas Tubing - Buriable Gas - 4EHF1 : Grainger Industrial Supply
Old 10-26-11, 11:48 AM
Temporarily Suspended
Ask for a coupling wherever you buy the the pipe. They should know what to use.
Old 10-26-11, 12:17 PM
lawrosa's Avatar
Super Moderator
Received 25 Votes on 23 Posts
I always bought the risers with the stab fittings built into the risers.
It is cheaper then buying the stab couplings seperate.
Thats the last time I priced it anyway.
Example.
http://www.perfectioncorp.com/en/dow...ingles_(4).pdf
Mike NJ
Old 10-31-11, 07:44 AM
Smile
Thanks guys for your response.
HTML code is On
