Leaking Water Pressure Regulator
Closed Thread
Old 11-02-11, 04:39 PM
I have a leak at the regulator screw/lock nut (not sure if that's the correct terminology).
Would cleaning the strainer screen stop the leak, or does the whole thing need to be replaced.
Does a plumber need to perform the repair?
No problems with water pressure, and it only leaks when water is used somewhere in the house.
Old 11-02-11, 05:07 PM
lawrosa's Avatar
Super Moderator
Received 10 Votes on 8 Posts
They have repair kits for them but they are as much as a new valve. A new valve is about 50 bucks.
Mike NJ
Old 11-02-11, 05:19 PM
Thank you for your reply. Is it easy enough for a person w/ no experience to do?
Old 11-02-11, 05:46 PM
lawrosa's Avatar
Super Moderator
Yes if you get the same tupe the connections may be similar. A union on one side, reusable, and threaded connnection on the other.
Mike NJ
Closed Thread
HTML code is On
