Constant drip from water heater drain pipe normal?
Old 01-10-01, 08:07 AM
Guest
Question
Hello, I hope someone can enlighten me about whether I need to do something about this. Our A.O.Smith water heater has a vertical copper pipe with a spigot connected at the top that is constantly dripping HOT water. I know this is a drain pipe, but it is always dripping! It seems like the amount increases when someone uses hot water in the house. Is this a leak or is it normal?
Thanks for your help.
Old 01-10-01, 08:39 AM
Plumber2000's Avatar
Not Normal
Sounds like it needs to be replaced, since it never stops, that tell me it's not a pressure related problem, or a tempature related problem.
But a new one at Home Depot and replace it. Shut off water to the tank before you unscrew it from the tank.
Plumber2000
Old 01-10-01, 08:46 AM
Guest
Smile thanks-one question
Will I need to drain the tank before disconnecting the copper pipe, or just shut off the water?
Thanks!
Old 01-10-01, 08:53 AM
After you shut the water off open a hot water side faucet to relieve the pressure, then replace the valve, no need to drain the entire tank.
Plumber20000
HTML code is On
