PEX Help Please
Old 12-06-11, 02:22 PM
D
PEX Help Please
I have never used pex. Can I use standard hose clamps on pex tubing? If not, should I use the clamp or crimp method? Thanks
Old 12-06-11, 02:28 PM
P
Temporarily Suspended
Pex is crimped.
_______________
Old 12-06-11, 02:35 PM
W
Received 1 Vote on 1 Post
Or clamped. I have not been able to find out if one method is better than the other.
However, hose clamps would be a no no.
Old 12-06-11, 04:57 PM
P
Received 973 Votes on 894 Posts
That is a big no on the hose clamp. I use the crimp on copper rings (they are colored black though) mainly because they are more commonly available in my area.
Old 12-06-11, 04:59 PM
Z
Received 206 Votes on 184 Posts
I'm still a PEX novice, but the crimp rings are a piece of cake to use. Be sure to get a go/no-go gauge and test your crimps occasionally to ensure the crimper is still within spec.
If you only have one or two connections to install, either borrow a crimper or use SharkBite/GatorBite fittings. If you're going to be plumbing for a while though, the crimper is certainly worth purchasing.
