Polybutalene Compression Fitting Failed
Old 12-16-11, 06:46 PM
Received 2 Votes on 2 Posts
My tenant called this morning and said the pipe broke. Upon inspection a 1-1/2 yr old PB compression fitting came apart where it connects to the stop under the kit sink. Fortunately, they shut the main house stop before major damage.
My question: Are these things an endemic problem? The hot side failed, but I checked the compression nut on the cold and it was not very tight. I installed these myself, so I know things were properly snugged. This is a Delta faucet with the factory installed grey PB supply lines. This wasn't my first rodeo, but I can always learn something new.
Old 12-16-11, 08:17 PM
chandler's Avatar
Were you using the nylon ferrules or metal ones?? PB will require the use of nylon in order to get a good seal.
Old 12-17-11, 10:15 AM
It was a nylon ferrule, supplied by Delta. It sealed fine for almost two years and then just blew apart. If tenants had not been home, the damage would have been catastrophic.
HTML code is On
