Problem with New Sump Pump
Old 05-01-12, 01:15 PM
L
I recently purchased the 1/3 HP pedestal sump pump here:
Diamond 309907A 1/3 HP Pedestal Sump Pump Thermoplastic : SPV500-RB : VMInnovations.com
I connected a check valve and 24ft of 1-1/4" corrugated pipe. The pipe runs up my 8ft basement wall, then about 20ft or so above my dropped ceiling before exiting the house to the storm sewer. The problem is that the pump doesn't seem to be powerful enough to push the water all the way out. By feeling the weight of the pipe, I can tell the water makes it up the 8ft vertical but stalls out about half way across the 20ft trek to the other side of the house.
As an experiment, I tried running all 24ft with no vertical (across the room and into a bucket). It seems to handle that just fine.
I'm just wondering if a 1/3 HP pump should be able to handle a 24ft trek with a vertical height of 8ft. If so, does anyone have any suggestions?
So far I've:
- Drilled a weep hole per the installation instructions to prevent air lock
- Tried taking the check valve out
- Checked the impeller for obstructions (didn't take it apart, just looked at where the water enters the pump)
- Tried two different power outlets
Thanks,
Dan
Old 05-01-12, 06:08 PM
D
My guess is that the water sits in a low spot in the flex pipe. Get yourself setup with rigid PVC pipe and slope it downhill.
Old 05-07-12, 02:21 PM
2
The water is the probably not effectively flowing to the sump pump. The water that does not get sucked up by the pump may be a result of malfunctioning pump.
