humming in water pipes when turned on
help me humming or ringing pipes!
pipes are pvc and they make a humming or ringing noise when you turn on the shower and dishwasher! can someone help me !
Re: help me humming or ringing pipes! please i need help with pipes
Get a water pressure gauge and test your pressure, this one attaches to a hose bibb outside. if it reads 80lbs of higher then you need a pressure reducing valve With high water pressure, when water can move fast in the water pipes, it creates friction, in-turn makes sounds, this is increased noise when hot water is in use, then when the gets to the valve, i.e. shower, dishwasher, and it flows though the smaller passage ways of the valve, makes increased louder noises.
