Drain line
I have a similar problem to Howardlr...drain line for washing machine. The machine drains ok, but the line from the house to the tank is leaking and the drain water is showing above ground. No problems with the tub/toilet lines so I know it's not the tank. Will the snake work in this line? How do I know if the line needs replacing?
You will need to rent a machine like this one form the rental yard, if there is anything really wrong with the line to the tank you will know. Be careful, the machines at the rentals yards are not the best to use.
Plumber2000
Plumber2000
