WASTE CHECK VALVE
Old 01-21-01, 07:55 AM
Angry
I HAVE HAD THE CITY SEWER SYSTEM BACK UP INTO MY BASEMENT SEVERAL TIMES,I UNDERSTAND THAT A WASTE CHECK VALVE IS AVAILABLE TO PREVENT THIS,I AM FAMILIAR WITH THE OPERATION OF A WATER / CHEMICAL CHECK VALVE, BUT HAVE CONCERNS ABOUT A WASTE CHECK VALVE CLOGING UP. DOES THIS VALVE NEED TO BE INSTALED INSIDE THE HOUSE FOR MAINTENANCE OR CAN IT BE INSTALLED IN THE YARD ON THE MAIN LINE TO THE SEWER. I WOULD APPRECIATE ANY INFO FROM QUALIFIED PLUMBER ON THIS SUBJECT.DRAIN LINE IS IRON PIPE
Old 01-21-01, 08:59 AM
Plumber2000's Avatar
They work, code requires them for certain things, you can put it inside or outside, make sure it will be accesible.
HTML code is On
