tub drain no longer stops water
Old 01-23-01, 12:55 PM
Angry
Suddenly my bathtub no longer holds water. You can move the lever back and forth but the damper never catches. I moved it up and down a few times and it caught once but now it does not do it at all any more. ?? Am i going to have to go into the wall to fix this? can i do it from the crawl space?
Old 01-23-01, 01:08 PM
Plumber2000's Avatar
Remove the face plate screws now pull the entire assembly out, you need to adjust the linkage down lower, this is a trial a era task, once you have it set again tighten the face plate back up.
HTML code is On
