toilet bowl leaks
Old 01-24-01, 02:33 AM
Unhappy
replaced fill pipe assbly. replaced bowl on toilet,even used silicon on bolts(3) but it still leaks dripping down bolts.
Old 01-24-01, 07:25 AM
Plumber2000's Avatar
Did you install a completely new tank to bowl kit as showen in this picture?
Don't use silicone.
Follow what I say and it will be leak free.
Take it all apart,
Bolt assebly order, how I do it, and garanteed not to leak.
Bolt > Rubber Washer > Slip Into Tank Hole > Rubber Washer > Metal Washer > Nut > Tighten It.
Do the same for both side, this step is done before you mount the tank to the bowl.
Now slip the large sponge gasket onto the bottom of the flush valve.
Set tank onto bowl, not use the last nuts and washers and snug the tank down. Do Not Overtighten
Old 01-24-01, 11:05 AM
Originally posted by Plumber2000
Set tank onto bowl, not use the last nuts and washers and snug the tank down. Do Not Overtighten [/B]
Last instruction was meant to say NOW USE THE LAST NUTS AND WASHERS AND SNUG THE TANK DOWN.
Old 01-24-01, 11:58 AM
Thanks for correcting me
Sometimes the fingers the the wrong keys.
Old 01-26-01, 02:03 AM
Talking
Thank you ror the advise. Used fender washers to keep from pinching the felt? washers, found that after I took it back apart. NO leaks now.
HTML code is On
