drain backup
Old 01-25-01, 11:58 AM
my toilet is backing up into my bathtub when the toilet is flush sept of 99,I had a plumber come and he clean out the main drain.by forcing water through the drain,that lasted till last summer when I had another plumber come and he clean out the drain with a roter.Now I'm having the same problem.Is there a way I can take care of this problem myself?Is there a solution on the market that I can pour into the the bath tub or toilet that can clear this problem ?I don't know what type of pipes my house has the house was built in 1960 in the south(Ark.)
Old 01-25-01, 07:53 PM
Plumber2000's Avatar
The best cure for a problems mainline is replacement, other then that, getting it cleaned out when needed is all that you can do about it.
HTML code is On
