compatability
Does anyone know if I can "marry" pvc to steel or cast pipe. I have an existing basement toilet with an apparent steel pipe stub and metal closet hub. I was thinking of oakam....any suggestions?
Ray the electrician
Ray the electrician
Hi Ray,
Is the top of this stup up flush to the finish floor?
If so I would say go to a plumbing supply house and get a fange called an insta-set, or some call them a quick set, this slips over the outside of the pipe and then you tighten up 4 bolts, when tightening it will squeeze the rubber gasket to the outside of the pipe, giving it a tight seal.
Hope thats what you need to hear.
