Toilet Drain
Old 10-10-12, 09:11 AM
Toilet Drain
Which of these is the best configuration for a toilet drain ?
Going to assume that C is incorrect because of no immediate vent pipe; that leaves A or B.
Which one would be the best configuration ?
Thanks,
Arky
Old 10-10-12, 10:11 AM
lawrosa's Avatar
Super Moderator
Received 19 Votes on 17 Posts
You will need to vent the line from toilet to stack regardless of which one you use.
Old 10-10-12, 10:36 AM
Sorry, I wasn't clear on the main stack; it is the main vent.
That being, which would provide the optimum water flow, A or B ?
Thanks,
Arky
Old 10-10-12, 10:50 AM
lawrosa's Avatar
Super Moderator
What else ties into that main stack, and where?
Both will perform the same.
Old 10-10-12, 04:40 PM
Well, this is assuming that nothing else ties into the main stack, and the main stack
is also the main vent.
I've posted this on several other forums and so far, the B's have outnumbered the A's.
The A proponents mostly say that it's a straighter shot, thus less chance of clogs.
The B proponents say that the A allows too much rush of water, thus restricting the vent.
I'm still 'up in the air' about which one to go with, but, not being a plumber,
if left to my own impression, I would probably have chosen A.
Anyone have a strong argument for either ?
Thanks,
Arky
Old 10-15-12, 09:47 PM
In the following picture, assuming that the 'other drainage' pipe cannot be moved, which would be the better arrangement, A or B ?
Thanks,
Arky
Old 10-15-12, 11:02 PM
lawrosa's Avatar
Super Moderator
A. Otherwise you would need to vent the toilet in B. Also other drainage will most likely have a vent I assume.
Old 10-19-12, 09:10 PM
One last time on the toilet drain.
Because of obstructions and space limitations, I need to have the toilet drain into the
stack lower than the tub and sink.
Would there be any potential problems with this arrangement, that is, having the sink and tub drain into the stack about a foot above the toilet inlet ?
Thanks,
Arky
Old 10-19-12, 10:07 PM
lawrosa's Avatar
Super Moderator
You will need to vent the toilet then...
Not sure what you are trying to do here but its getting silly IMO. Why not just buy a code book?
You have given 10 or so different senerios. ( This and your other post) I think you know what you need to do and if your not sure I suggest hiring a licenced plumber.
HTML code is On
