Toilet won't flush
Old 01-27-01, 05:11 PM
Guest
Smile
Hi, toilet won't flush. !. When I flush the toilet the water in the bowl will go down some but not all the way, just half way. The water in the tank will work like normal. When I flush the toilet the tank water will go down and rise with no problem I've tried pulling the flapper plug out, therefor all the water will drain and the toilet should flush, however this did not work. I've tried using the plunger and that did not work. What can I do??? What's wrong??? Jon
Old 01-27-01, 06:13 PM
Plumber2000's Avatar
Clean the flush ring holes out, and check and make sure the blow hole in the bottom of the toilet as not pluged up.
HTML code is On
