Plumbing codes
Plumbing codes
I am going to try to compile some links for various plumbing and gas codes. This may be ongoing for a while so bare with me. I will edit as I go.
I will try to find state and national and post accordingly. This way many can look up codes for themselves to help their DIY repair or renovation.
Send me a PM if you know of links from your state level, and you want to help out.
National Codes
GAS
National Fuel Gas code 2012 NFPA 54 ( You must register to view. Its free.)
NFPA 54: National Fuel Gas Code
International Fuel Gas code 2007.
International Fuel Gas Code
PLUMBING
Uniform plumbing code 2007. (UPC)
( Check to see if your state follows this code. Its in PDF form for each chapter. I am trying to figure a way to consolidate.)
Pages - DownloadCenter
International plumbing code 2007 ( IPC )
( Check to see if your state follows this code.)
International Plumbing Code
New Jersey
International fuel Gas code. NJ Edition 2006
New Jersey Fuel Gas Code
NJ National Standard Plumbing Code 2006
( I believe Maryland follows this code also and is the only other state.)
New Jersey Plumbing Code
National Codes
GAS
PLUMBING
New Jersey
Thanks for listing out code documents Mike!
I have found these reference documents quite helpful too when preparing for inspection. They are tailored to Washington State, but most of the requirements should be consistent for most locales.
Residential Plumbing Rough-In
Residential Plumbing Final
Other construction checklists
