Leaking pipe outside, suggestion for repair methods?
Old 11-30-12, 10:37 PM
F
I have a pipe outside my house that has a small leak. I attached a YouTube video and some pictures of it.
YouTube video: Leaking pipe outside the house - YouTube
Images:
Appreciate any advice and comments in advance!
Old 11-30-12, 10:43 PM
Received 1,480 Votes on 1,368 Posts
The You Tube video is empty.
Old 12-01-12, 05:06 AM
B
Is that riser pipe iron ?
P
Received 868 Votes on 799 Posts
I assume this is PVC feeding an irrigation system. It looks like you'll have to cut the PVC and either try re-taping and tightening the threaded fitting or get a new one. Then use a union fitting to join the pipe back together. With things in a straight line it's going to be difficult the pipe length correct to get everything back together so just expect that you might have to cut the pipe a couple times until you get it exactly correct.
Old 12-01-12, 05:12 PM
W
Received 12 Votes on 10 Posts
Hi, They make a PVC compression fitting for that type of repair. It will allow enough space so you can cut the pipe then cut off the fitting install a new fitting then put it back together.From your picture I would cut the pipe about 3 or 4 inches off the ground so I have the longer piece to work with.
Good Luck Woodbutcher
