Ouch!! Broken catch drain for cloths washing machine drain.
Old 12-06-12, 09:03 AM
biketrax's Avatar
Received 1 Vote on 1 Post
So my neighbors free standing 3 ft high catch drain aprox 2" dia specifically designed for her cloths washing machine was slightly clogged. The water was coming up the 3 foot pipe and spilling over. She asked me to look at it since I do most of the handy man things for this elderly single women. well upon slight force the casting catch drain broke so I must take these rusty piece out and figure a way to incorporate some pvc into this drain system. Which thus feeds into a 3" vertical drain. Any suggestions? I know this may be hard to visualize or understand since its hard to explain. will try and post a pix.
Old 12-06-12, 09:10 AM
lawrosa's Avatar
Super Moderator
Received 55 Votes on 48 Posts
Yes post a pic.
I assume its steel pipe? Probably can use a no hub fitting but will need to support pipe if so.
Old 12-10-12, 07:00 AM
biketrax's Avatar
fixed with PVC
Glued some PVC parts all worked out well!
will post a picture when I get a chance!
thanks
HTML code is On
