How to tie 3/4" pvc into 3" abs
Old 12-11-12, 08:48 AM
D
I just purchased a upflow toilet for our basement and I was just wondering how to tie the 3/4" pvc from the upflow to the 3" abs sewage stack?
Old 12-11-12, 08:59 AM
lawrosa's Avatar
Super Moderator
Received 55 Votes on 48 Posts
What is the make and model upflow toilet you purchased?
We can guide you better with this info.
3/4" PVC???? Huh!!!!
Old 12-11-12, 09:06 AM
D
It's a saniflow sanibest. It pretty much chops everything up into mush and then pumps it up the 3/4"
Old 12-12-12, 06:13 AM
A 3/4 line does seem awfully small for this application. But if that's what the instructions say to use, it must be OK. Joining dissimilar plastic pipes is iffy since they all use different kinds of cement. You could try a saddle tee if you can find a 3 x 3 x 3/4. Oatey makes the tees, and probably others as well.
Old 12-12-12, 07:18 AM
D
Yeah I thought 3/4 was small too, but I guess it chops everything up into such fine pieces and then pumps it though the pipe. I would upsize it to 1" but they call for 3/4" so 1" might drop the pressure too low to pump everything up. I will look into the saddle tee. Thanks
Old 12-12-12, 07:19 AM
lawrosa's Avatar
Super Moderator
Tie in with a wye on a vertical stack.
15 ft vetical max before running horizontal.
No AAV ( air vents allowed) Must vent properly.
http://www.saniflo.com/upload/produc...l_sanibest.pdf
That unit will be more trouble then good IMO. Hope it works out for you.
HTML code is On
