Hose Bib Question
Hose Bib Question
I have a hose bib that the treads are a little bent so when I try to put on a hose it does not tighten completely for that reason it leaks at the bottom of the hose. Question, is there a way to fix the tread on the hose bib? Or does it have to be replaced? Really would not like to solder. Thank You for any suggestions.
