hot water heater pop off valve leaking
Old 02-04-01, 05:09 PM
Guest
i have a leaking gas hot water heater pop off valve i had a plumber install a new pressure value but it is leaking again. what is causing the problem? also my home is heated with this hot water heater.
Old 02-04-01, 07:07 PM
Plumber2000's Avatar
Received 2 Upvotes on 2 Posts
Sounds like thermo-expansion is taking place, installing a thermo-expansion tank should solve this problem
