what grade of no hub cast iron should i use for residential use?
Old 03-04-13, 12:30 AM
T
what grade of no hub cast iron pipe should i use for residential use? there seems to be 3 grade types or 2 types like heavy duty and service weight. i am currently going with type L copper for my water supply lines that i am installing since i do not like type M since it seems to light weight. but anyhow what grade of no hub is best and what types of no hub are good for what places.
Old 03-04-13, 07:03 AM
W
Received 20 Votes on 19 Posts
Cast Iron Pipe
You may find this helpful:
http://www.abifoundry.com/Catalogs&H...I_Handbook.pdf
Old 03-11-13, 05:33 AM
T
can a soil pipe snap cutter cut through threaded galvanized pipe or just cast iron?
Old 03-11-13, 11:31 AM
P
Temporarily Suspended
I believe it's just for cast iron. Why don't you want to use PVC, in place of cast iron?
Old 03-14-13, 08:39 PM
T
i used PVC in the past but do not like working with it. also i did not find to much info in the pdf doc. i need to know if there are 3 or only 2 grades of no hub cast iron pipe.
Old 03-15-13, 02:39 AM
P
I never installed cast iron so I don't know about the grades. Check with you local plumbing supply.
Old 03-15-13, 03:49 PM
Z
Received 128 Votes on 119 Posts
I've never installed cast iron either, but found this that may be helpful:
Cast Iron, PVC, ABS, and CPVC pipe and fittings for plumbing and industrial systems
Seems there are two grades of Hub and Spigot pipe, but only one of hubless for DWV plumbing use.
HTML code is On
